Unable to delete a file in Fusion 360
firebloodphoenixHRBBH
A long while ago I was doing some tests in fusion,in render and simulation.
but now I cannot delete these files, it just says "this document is in use and cannot be deleted"
These are simple files that are not referenced by other files as far as I know. I even made sure by checking the versions too
I already tried doing a small edit and resaving it
I went to the https://myhub.autodesk360.com/ but it just says "in use"
I am the only sues using them
How can I force to delete these files?
jodom4
Hey firebloodphoenixHRBBH,
Try restarting F360 and clearing the cache. This usually solves the problem you're experiencing.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Tried it but it did not work, I think this is an issue on A360's drive....
