Unable to Create Section View
pr4k8MVCC
Observer Observer
pr4k8MVCC
Observer
Observer
I am attempting to follow along the 'Intro the Fusion' tutorial from Autodesk in creating a technical drawing of a brake rotor. I have the parent view on the sheet already, and when I press create or hit enter after drawing the section line through the middle of the part. it closes the drawing view panel and does nothing. The 'ok' button stays greyed out all the time and I have already tried restarting Fusion to no avail.
jhackney1972
You are sketching the Section Line over top of itself.  Hover over the center, like you started, but do not click.  Drag your cursor up along the dashed green line until you get to the outside of the view, then click.  Drag the line back across the view to the other side and click, then select the green check mark to finish and place your section view.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
pr4k8MVCC
Observer
Observer
I appreciate the help, I was trying to follow exactly as how the tutorial showed from Autodesk.
