Unable to add draft to some surfaces in model - help please
Message 1 of 9
I've designed a relatively simple heat press mold in F360. I need to have 10 deg. draft on all surfaces. I had no trouble on all but three edges, but cannot find the reason I get odd behavior or just error messages on the last three of them...
Could someone please put me on the right path and/or find my errors?
The jpg file shows which surfaces don't have draft. I also noticed a glitch with extrusions in the "x" corners that I can't fix. These are not critical but I'd like to know what I did wrong - if someone can be bothered to check.
Lastly, I don't know how to share a file from my cloud storage here  - or to anyone else. How do I do that, please?
Cheers,
Joe Hovel (in Australia)
Replies (8)
Message 2 of 9
g-andresen
Hi Joe,
1. clean up the sketch with its multiple (2 / 3 times) lines
2. extrude with taper
günther
share design via data panel
Message 3 of 9
Thank you very much Guenther!
How can I find duplicate lines in my sketches, please? I've occasionally found some accidentally, but I have no idea how to go looking for them deliberately 🙂
Secondly, I had no idea you could extrude with taper. That will make things like this much easier!
Cheers,
Joe
Message 4 of 9
That didn't quite work.... The taper extrusion isn't possible as it turned out, because its not allowed to overlap - draft is - in narrower spaces than the angle of the taper allows....
Back to cleaning up the sketch: I found a few duplicate lines by the laborious process of deleting lines and seeing if they disappeared: if the didn't, they were duplicates... THERE MUST BE A BETTER WAY.
Found a couple of microscopic discrepancies. Finally I was able to apply draft to all flanks.
Now I get a completely new error message when I try to generate milling tool paths: apparently there is a face missing in the model. I can't find anything missing.....
Always two steps forward one step back 🙂 I'll keep trying to figure it out or will put a new post here.
Message 5 of 9
g-andresen
1. taper is always limited by the geometry
2. double lines can be found like this
3. constrain the sketch
günther
Message 6 of 9
Thank  you again Guenther!
Always very helpful.
Cheers,
Joe
Message 7 of 9
 Dear Guenther,
I just went to check out my entire sketch to look for remaining duplicate lines.
Now EVERYTHING is going wrong.... When I open the sketch I get the warning that a face is missing, then the body disappears and the sketch is completely different (lots of blue squares on all lines). When I click on anything, I get an error message to say that "some of the features are set to invisible" and the whole sketch disappears. When I saved it, the whole file is empty! This is very frustrating.... I went back to an earlier version and exported it to my desktop for backup.
Would you please have a look at it and tell me what I'm doing wrong now?
As I mentioned earlier, I am still unable to create anything in 'Manufacturing' as tool paths - that worked perfectly yesterday with the model with still missing draft sides. Now that all the sides are as they should be (as a result of your advice), I can't get any further with tool paths at all.... The error message is the 'missing face' that I can't find - yet it is clearly visible in the model.
I'm right out of my depth with this - after 6 months of formal school and lots of other modelling without any issues (but no drafts or tapered extrusions, haha...).
Kind Regards,
Joe
Message 8 of 9
g-andresen
Hi Joe,
1. the visibility of the sketch was disabled
2. I have edited the text sketch in V-Carve.
I removed the outer contours (CX) and added them again with offset incl. corner editing.
After the import into Fusion it looked much better.
günther
Message 9 of 9
Thank you again for your helpful assistance Guenther!
Your version changed some of the critical dimensions, but it allowed me to see how you went about it. I was able to do exactly what I need to as a result.
It is a steep learning curve but learning is the purpose of these projects for me!
I love being able to ask someone - exactly what these forums are for, of course.
Kind Regards,
Joe
