UI Theme Preview (dark mode) - Feedback & Discussion
keqingsong
Community Manager Community Manager
Message 1 of 164
keqingsong
*March 25, 2025 - Fixed for March 2025 Product Update:
• Timeline scroll bar is no longer missing.
• Highlight colors for activated component are now correctly themed.
• “Read Only” or “Editable” drop down menu in document thumbnail is now correctly themed.
• Version icon is now consistent across themes.
• Activated and inactive Simulation Study and Load Case highlight colors are now correctly themed.
• Render On Save text is no longer missing.
• Command dialog slider arrows in Render are now more visible. Render Viewer dialog is now correctly themed.
• Render Settings dialog is now correctly themed.
• Text highlight color in Save version, Save As, and other dialogs is now darker.
• Timeline tooltips on hover are now correctly themed.
• Text in Dialogs for New / Edit Plastic Rules are now correctly themed.
• Text for “Pin to Toolbar” and “Pin to Shortcuts” flyout text are now more visible.
• The “No components in design” dialog is now correctly themed.
• Activated Fluid Conditions highlight colors are now correctly themed.
• Document type icons (design, electronics design, PCB, and Schematic) in Data Panel are now dark theme compatible.
• Close, Search, Update, Refresh, Open, and Milestone icons in Data Panel have been updated to dark theme compatible versions.
• NC Program dialog experience is improved and now correctly themed in dark mode.
• NC Program dialog is no longer missing border space around the edges of the dialog.
• NC Program dialog layout is now correctly aligned in dark mode.
• Fixed an issue where the Expression Editor dialog made the toolpath dialog go blank.
• Icon for Manufacturing Assistant is now clearly visible in dark mode.
• Process order number column header now has correct colors on Windows machine when Dark Blue theme is active.
• CAM setup name in the browser is now more visible in light gray mode.
• Machine Library dialog experience is improved and is now correctly themed in dark mode.
• Hole Template Editor experience is improved for dark mode.
___
If you try the UI Theme Preview (dark mode) and see any weird behaviors or issues, please report them here. Screenshots are highly encouraged. Our developers are watching and engaging with you; what you submit will help us prioritize future improvements.
___
Many of you have been wishing and waiting for dark mode for a long time, so we hope you'll be excited to know the rumors in the community are true: UI Theme (aka dark mode) is finally coming to Autodesk Fusion.
We’ve been working hard to get you the ability to switch themes in Fusion and we’ll soon be making it a preview feature, available to try as part of a staggered rollout. This means that not everyone will get access to the preview at first, but more and more of you will eventually get access as we continue to mature the experience.  This way we can ensure the functionality is working in tip-top shape when it becomes available to everyone.
To check if you have access, Go to your Preferences > Preview Features > UI Theme. If you see the UI Themes Preview option, checking it and then clicking on “Apply” will turn the option for you to change themes. Navigate to General section of your preferences. You should now see a Theme option. Change from Fusion Classic to Dark Blue and click “OK” and you should be ready to go.
Note: If you previously changed the Display Settings Environment to a different canvas color, your previous settings will be retained.  To have the canvas color follow your chosen UI Theme, go to Navigation Bar > Display Settings > Environment and select Theme (default).
We’re still actively developing this feature, and we want your feedback
As stated above, theme switching is not done; we are actively improving the experience. Due to the expansive nature of Fusion and all the workspaces, we’ve primarily focused on fleshing out the Design workspace and the most common workflows. We want to make sure dark mode works well for every aspect of Fusion, across macOS or Windows, and with whatever machine you’re on.
If you try dark mode and see any weird behaviors or issues, please report them here. Screenshots are highly useful. Our developers are watching and engaging with you; what you submit will help us prioritize future improvements.
Thank you for your help and support!
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Replies (163)
Message 41 of 164
FrodoLoggins
Ok well I'm sure someone at Autodesk has seen that because it happens all the time on every design.
When am I going to be able to click on an item in the browser to show its subcomponents without Fusion thinking I held my mouse button down and want to instead drag the component? Because that happens all the time on every design since the last update. It's happened before over the years but after this update it's way too often, someone at Autodesk had to have noticed.
If I create a section view and click on a circular face the obvious expectation is that that section view is smack in the middle of that bore. Not .0002" off center one time and on the next try it's .0001" off in the opposite direction, and then on the third try it's .03" off, and then finally after the 4th try it's centered on that bore. I can't triple check every single little thing I do I need to get some work done.
If you guys are going to rush every update out maybe fix the bugs? Otherwise they just pile up. It's been over 6 years on 3 different brand new computers and this program just gets buggier and clunkier.
Starts sketch > Loading symbol > Draws one single line segment > loading symbol > beach ball of death > second loading symbol for some reason > welp that's lunch.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Message 42 of 164
FrodoLoggins
Adds chamfer to edges > Makes forum post > Comes back to Fusion and the edges just stay glued to my screen:
What's the solution restart Fusion 50 times a day?
Message 43 of 164
jeff_strater
I have not seen the incorrect underlining.  If it happens on every design for you, please just supply one that shows it so that we can reproduce it.
Also:  As @dfanz0r suggests, this thread is supposed to be about Dark Mode, and a lot of your topics (this one included) are not related to Dark Mode at all.  Please keep your reports topical to the subject.
Jeff Strater
Engineering Director
Message 44 of 164
FrodoLoggins
Great now this tooltip won't go away even though I closed the dialogue it's assigned to:
Doesn't go a way until I hover my mouse over the browser:
I'm going to hit "Reply" to this post, I'm going to go back to Fusion, and within a minute I'm going to notice either a bug or a beach ball of death. At at least one point today Fusion will just permanently change my mouse cursor to the "resizenortheastsouthwest" cursor for no reason despite me never trying to resize anything.
Message 45 of 164
FrodoLoggins
@jeff_strater I got a a twofer for ya you want the model I need your email:
Message 46 of 164
FrodoLoggins
Wasn't this supposed to be fixed 6 months ago? Why is Fusion taking up 2 spaces in Mission Control?:
Message 47 of 164
jeff_strater
the pattern at Autodesk is [email protected].
Jeff Strater
Message 48 of 164
FrodoLoggins
Email sent.
Well my lollipop mills no longer look like helmet heads on setup sheets (only took 3 years for a bug fix) but my form mills still don't look right.
This is what Harvey tool #807312 looks like:
Notice how it doesn't look like a square end mill.
This is what that tool looks like on my setup sheets:
Message 49 of 164
keqingsong
Thanks for all your feedback @FrodoLoggins, and thanks @jeff_strater for helping. I will call out that your recent posts have strayed away from the original intent of this thread, which is to specifically give feedback on UI Theme Preview. If there are other things you need help with or want to report on, please start a new thread  so the team can stay focused on the topic at hand.
Keqing Song
Message 50 of 164
JoshuaO_
Parameters cannot be added to configurations using new UI themes. The checkbox does not toggle on click. Tested on both "Dark Blue" and "Light Gray". Only works as expected with "Fusion Classic" theme.
Message 51 of 164
a.laasW8M6T
Pending updates notification the "1" beside the clock is very hard to see
Andrew Laas
Senior Machinist, Scott Automation
Message 52 of 164
keqingsong
Thanks for this @JoshuaO_ , will let the team know.
Keqing Song
Message 53 of 164
keqingsong
Thank you @a.laasW8M6T , we have this captured and will add it to the backlog.
Keqing Song
Message 54 of 164
a.laasW8M6T
In dark mode the Post/Cancel buttons are right up against the Dialog border
vs classic
Andrew Laas
Message 55 of 164
a.laasW8M6T
Cancel button when installing VS code is hard to read
Andrew Laas
Message 56 of 164
Broz.Jk
Finding any operation on the timeline is almost impossible.Snímek obrazovky 2025-02-13 093720.png
Message 57 of 164
mikeprice_ksbooms
Sorry if this was already reported but the Print dialog is washed out in a few places. Screenshot 2025-02-13 110540.png
Message 58 of 164
InnovatoolsSimon
Delete group options are white on white.
This has been mentioned for Mac as hard to see, but for windows it's impossible to see.
Cheers
light gray theme
Dark Blue theme
Message 59 of 164
GreenEnergyPulse
Observer
Observer
Hello, I think dark mode is amazing. Here are the issues I have noticed:
When you open up the "Capture Image" menu some of the text is unreadable.
When you click on the three dots that pull up the menu to "Add to Toolbar" and "Pin to Shortcuts" the text is hard to read.
The dialog box to change the color under Render>Scene Settings>Color has unreadable text.
Some text in the Material Browser in illegible.
Thank you for your work on Fusion.
Message 60 of 164
HobbyBuilt
Agreed, the blue looks really dated. Better to start on the black version before they head too far down this dark blue rabbit hole.
