10 document limit for personal use seems to be 5
jdaues
Message 1 of 8
jdaues
I am unclear on the 10 document limit. I get a message that I have reached the limit of 5 documents. If I change one of the documents to Read only such that I have 4 editable documents, then indeed I can edit another document. This seems to contradict the 10 document limit. How is my thinking incorrect?
Replies (7)
Message 2 of 8
lance.carocci
Thanks for the report, @jdaues. I am looking into this.
In the meantime, would you please confirm what version of the application you have installed?
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 3 of 8
jdaues
diagnostics file attached
Message 4 of 8
patilsm
Hi @jdaues,
Thank you for reporting this issue.
I am currently trying to reproduce it locally on my system. I noticed that I receive a message stating, "Upgrade to get unlimited access," but I am still able to edit 10 documents.
Could you please share a screenshot of your Data Panel for further investigation?
Thanks and regards,
Sagar Patil
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 8
jdaues
The problem no longer occurs. The only thing I can think of is that I set all documents to read only and then back to editable again and that somehow reset it.
Message 6 of 8
sacchetti.g
Observer
Observer
Hi, I had the same issue after opening Fusion. In the top left corner I had "4 of 5". After download last version (before restarting) the number of editable documents was restarted to the correct limit (10).
FYI I report the sequence of actions I take:
1. Open Fusion
2. Autenticate
3. Fusion show 4 of 5 editable documents (limit seems 5)
4. I switched 3 docs to read only
5. In the meantime started the download of the last version
6. After the end of download and install (before restarting) I see the number of editable documents limit is restarted to 10 and 3 of the documents I marked read only are still editable.
7. Restart Fusion for update
8. At the end of restart Fusion show the correct limit.
I was not able to take the screenshot of the error. I attach the screenshot of the updated and correct limit.
Hope can help. Regards.
Gabriele.
Message 7 of 8
falk6QAEM
Community Visitor
Community Visitor
It's zero now...
None of the proposed fixes works.
Message 8 of 8
jhackney1972
You are reading this statement wrong.  You have all 10 available documents you can edit.  If it read, 4 of 10 Editable Documents, then you have 6 more available.  In the Animated GIF I show you have have 0 of 10 Editable Documents and then I make one Editable.
John Hackney, Retired
