Hi @george
Thanks for posting! I had a look at your crash recovery reports and it appears that the crash you experienced was due to a known problem in which the CTRL key is held while in the long left click "Select Other" menu. Avoiding the use of the CTRL key while the Select Other menu is active should help you avoid this crash - I have made a note of this post on our development teams report for this behavior (FUS-25555). We appreciate you bringing this to our attention!
To check for any recovery files you may have missed, I would begin looking for the file in the crash recovery folder in Fusion, illustrated in this article. Remember to enable hidden files and folders!
If this does not work, it is possible that some missing files have not been uploaded to A360 cloud storage and may be found in your local cache folders, which you will need to enable hidden files and folders for Windows or Mac to access. To check your local cache folders:
- Open Windows File Explorer or Finder (Mac).
- Browse to the following filepaths;
- Windows: %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\<Custom Log-in ID>\W.login\F
- Mac: ~Library/Autodesk/Application Support/Autodesk/Autodesk Fusion 360/ <Custom Log-in ID>/W.login/F
- Designs containing assemblies with x-references will be found at the filepaths below;
- Windows: %LOCALAPPDATA%l\Autodesk\Autodesk Fusion 360\<Custom Log-in ID>\W.login\Q\_XRef_
- Mac: ~Library/Autodesk/Application Support/Autodesk/Autodesk Fusion 360/ <Custom Log-in ID>/W.login/Q/_XRef_
I would like to mention that the auto-save feature should not be relied upon 100% of the time - it is a good idea to save to the cloud frequently and create a local archive copy towards the end of the design process. If Fusion 360 is actively working on a process (e.g. rendering, solving a simulation, using the edit form command, etc.. ) then the auto-save can be skipped. Instead of relying on auto-save, you could use a lesser known feature allows the save a recovery file which does not sync with the cloud. To manually save a recovery version of a document, you could use the keyboard command:
Windows:
CTRL+SHIFT+S
Mac OS:
CMD+SHIFT+S
This recovery file will only be saved locally - no new cloud version will be created. The file will be found in the crash recovery folder as a "backup" format file, as described in this article.
Please let me know if you have any questions!
Paul Clauss
Product Support Specialist
