UI Bugs.
UI Bugs.
HughesTooling
Consultant Consultant
UI Bugs.
HughesTooling
First, the width of the browser is not remembered between sessions. This started with the new UI.
I don't have particularly long component names but still need the browser a bit wider, really annoying having to set every time I start Fusion.
Second, Old Old Old bug where only dialogs docked directly to the Right side of the screen resize correctly.
With the old UI you could workaround this by docking the dialog that resizes to the Right of the screen then dock the palette to the left of the dialog. You can do this with the new UI but it doesn't remember between sessions.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Bumping this unanswered post with a couple more bugs.
Right click option to Cycle Component colour is missing in surface and sheet metal workspaces. Display detail control missing in sheet metal and a divider is missing from menu.
Mark Hughes
HughesTooling
In the surface workspace right click on delete face is missing Edit option also layout of menu is different.
Mark
Mark Hughes
HughesTooling
Bumping this thread with another UI bug but not sure why I'm bothering as I feel like I'm talking to myself, 6 days no interest from Autodesk!
If the sketch palette is collapsed while another dialog is activated then close it ends up corrupted. This is related to my first post second problem where you have to dock dialogs that resize to the right of the window. Screencast below.
Mark
Mark Hughes
jeff_strater
@HughesTooling - this week has been Autodesk University, and all the people who would normally provide a response have been otherwise occupied.  I have this thread marked for follow up.
Jeff Strater
Engineering Director
pawel.potyrala
Hi @HughesTooling,
apologies for the late reply!
I already logged some of these in and I'll speak to @jeff_strater about these as well.
Thanks for your patience!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
HughesTooling
Another one I run into is no right click and Roll History Marker Here for linked components. Actually there's no right click menu at all so no find in window, browser etc.
Need to  roll to feature after the linked features and as I have a group I also need to expand the group first as well!
Mark
Mark Hughes
