TypeError: ni.getUserAgent is not a function
jwatte
jwatte
When starting up the current version of Fusion 360, I get the following error:
})(neuApplication, neuDev, neuInternal);
Script string  - line 60: TypeError: ni.getUserAgent is not a function
        var userAgent = ni.getUserAgent();
    at isblockedOS (Script string :60:28)
    at Script string :89:9
    at Script string :108:3
I don't think I've used any customized plugin, so is this just a problem in the current release? Which features should I expect wouldn't work?
Also, I guess the development team is in Germany, then? 🙂
mstrater
Can I ask if you're on Windows or Mac?
This error comes from a script used to ensure users aren't using very old versions of Fusion (so they won't run into issues related to client/server incompatibilities). Clearly there's some case where it's not functioning correctly, but I can at least assure you that this shouldn't cause you any problems as long as you stay on a relatively recent version of Fusion.
Btw, the "neu" that you see actually refers to "Neutron" which is an old internal project code name. 🙂
Max Strater
Sr. Software Engineer
lance.carocci
@jwatte, where does this message appear?
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
AccuTech52
I also have this message.
It is in the Text Commands window
