Tutorial sample keeps trying to save with error
wheels600
wheels600
One of the adoption 3d toolpaths keeps trying to save and is causing error after error.
 Help please.....I believe it is causing many errors with other Fusion processes.
mike.tessier
Hi @wheels600,
Thanks for posting!
Sorry to hear about this issue! It sounds like that sample file somehow got itself into your upload queue. Would you mind working through the instructions provided below to clear that upload out of there?
1. Close Fusion
2. Browse to:
       Mac
Macintosh HD > Users > *** > Library > Application Support > Autodesk > Autodesk Fusion 360 > *** > W.Login
       Windows
C:\Users\***\AppData\Local\Autodesk\Autodesk Fusion 360\***\W.Login\
(You will need to browse there manually - "***" is not a system variable)
3. Copy the entire Q directory and the UploadQueuedFileList.xml to a different directory for safe keeping.
4. Delete the Q directory and the UploadQueuedFileList.xml
5. Delete the jobs.json and the jobs.json.lck files located in:
     Mac
Macintosh HD > Users > *** > Library > Application Support > Autodesk > Autodesk Fusion 360 > *** > P.Login
     Windows
C:\Users\***\AppData\Local\Autodesk\Autodesk Fusion 360\***\P.Login
6. Restart Fusion
That should clear that error out of there.
I don't think that this would cause any other issues with Fusion processes, however if you would like to share your diagnostic log files with me, I would be more than happy to take a look and confirm this. To collect these, click the "?" in the upper right corner of the Fusion window and select "Diagnostic Log Files" from the drop down menu. This will package up everything I'll need to see in a zip file that can be attached directly to your reply.
I hope this helps! Thanks in advance for the information and please let me know if you have any questions or concerns - I am always happy to lend a hand!
Cheers,
Mike Tessier
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
wheels600
I am confused....I am not on a Mac
wheels600
Sorry.....my bad......I missunderstood you.....I managed to work through your instructions and it seems to be fixed.....Thanks man.
