Trying to project sketch onto sloping surfaces to then extrude.
tonynicholls2
Message 1 of 12
tonynicholls2
I am trying to add the sketch labeled Strap to the surfaces of Component1. This is simply a practice so that I can apply the technique to other models.
I have so far tried to draw directly on the surfaces and extrude, use loft, emboss and project in all its methods. I am failing to complete the task.
Can anyone help?
Replies (11)
Message 2 of 12
g-andresen
Please show in a hand sketch what you want to achieve and share the file.
File > export save as f3d on local drive > attach to post
günther
Message 3 of 12
tonynicholls2
Here is a drawing, I would like the strap to be one continuous piece. It will, when I am able to do so, put further details on the raised strap before I add it to the surfaces.
Thank you.
Tony
Message 4 of 12
Warmingup1953
Why not use emboss? You'll need to add two small fillets:Emboss.jpg
Message 5 of 12
tonynicholls2
I did try emboss in an earlier attempt but it didn't work. I obviously did something wrong somewhere. I'll give it another go.
Thank you.
Tony
Message 6 of 12
jhackney1972
Using Surfaces, you can get your desired strip and make is flush with each end of the angle surface.  The strip is 3mm thick.  Model attached.
John Hackney, Retired
Message 7 of 12
tonynicholls2
Sorry for the delay. That is what I was trying to do but for some reason the sketch didn't adhere to the surfaces. I will have another attempt.
Tony
Message 8 of 12
tonynicholls2
Thank you for the suggestion. I haven't tried using Surfaces before but it looks like it might solve my problem.
Sorry for the delay, other life gets in the way.
Tony
Message 9 of 12
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
Message 10 of 12
tonynicholls2
I am sorry for the delay in replying to yourself and the others, all had viable solutions. Unfortunately my browser decided to have a fit of the vapours and when I did reconnect the "Accept Solution" button was not displayed.
Thank you for your time. I now need to try and make the solutions work.
Tony
Message 11 of 12
jhackney1972
If you have issues with using my method, drop me a note, I will try and walk you through the process.
Message 12 of 12
tonynicholls2
Thank you for the offer. I appreciate your time. I will try myself initially, since this is a learning experience for me and I recognise that you have other things to do with your time. However, if I am truly stuck then I will be in touch.
Thank you.
Tony
