Trying to create channel in cylinder for shifting drum
tvicent
Observer Observer
tvicent
Observer
Observer
I'm trying to create a channel in a cylinder to make a shifting drum. I am trying to utilize the emboss tool to create an initial surface to work with however my channel is self-intersecting by design. How could I have my channel self-intersect without running into errors and maintaining parallel channel walls?
I am trying to emboss the projection onto the cylinder.
g-andresen
This is because the length of your sketch profile is greater than the circumference of the cylinder.
If you increase the diameter of the cylinder so that its circumference is larger than the stretched length of your sketch profile, it will work.
günther
tvicent
Observer
Observer
Yes, I am trying to have the channel intersect so that it is entirely continuous.
g-andresen
Then, when embossing, you must make sure that the length of the profile matches the circumference of the cylinder.
With the debossing option, the length must be reduced analogously to the debossing depth.
Nevertheless, a gap remains between the ends, which must be closed.
günther
g-andresen
You have to "play" with the profile a bit
(view in My Videos)
günther
TheCADWhisperer
To get the true geometry is a bit more complicated (in Fusion 360) than you might think.  It require a Sheet Metal workaround.
https://www.youtube.com/watch?v=Wekmai5MqFM
I think @jhackney1972  has a slightly more straightforward technique in Fusion - but I cannot find a link to example..
Hopefully he will come along and join the discussion...
g-andresen
Here is another possibility.
The embossing is produced on an unfolded sheet body and transferred to the cylinder by combined cutting after folding back.
(view in My Videos)
günther
