trouble uploading a step file
aeschlimandC569K
Message 1 of 10
aeschlimandC569K
i have tried several times to upload a supplied .stp file, i have tried both going through the upload tab as well as the 'open' directly from computer. when i use the 'open' option,
Error: Autodesk Translation Services failed to translate the step file, please make sure the step file isn't corrupt!
i cant seem to get it to do anything
Replies (9)
Message 2 of 10
jhackney1972
Please attach the STEP file if you can.  I will try and open it in another application to see if it is valid.
John Hackney, Retired
Message 3 of 10
aeschlimandC569K
i just sent it. let me know if you are able to open it
not sure where to go from here
Message 4 of 10
aeschlimandC569K
here it is
Message 5 of 10
aeschlimandC569K
nevermind, it wont let me attach the files
Message 6 of 10
jhackney1972
STEP files can be attached to Forum posts.  You must do it from the Forum itself, not from an email.  I attached one to this post to prove it.
Message 7 of 10
aeschlimandC569K
having trouble, maybe its the file? heres a screenshot
Message 8 of 10
aeschlimandC569K
this is what fusion is telling me:
Message 9 of 10
jhackney1972
Rename it, taking out all the garbage like the parenthesis etc.  Just name it test or something like that.
Message 10 of 10
HughesTooling
If you still get that error after simplifying the name then just ZIP the file and attach the ZIP file. The fact the forum is blocking the file might point to the file being corrupt and not recognised as a valid STP file.
Mark Hughes
Owner, Hughes Tooling
