Trim option in Fusion 360
Message 1 of 14
I have a Chassis Model in Fusion 360. I have made a 3-d Sketch using parameters and then used the pipe command to perform the piping on the chassis. Now I am stuck as I do not see any direct method to trim pipe ends. There exist interference between them and I need to remove that.
As there is trim option in SolidWorks to trim pipes, is there any way in Fusion 360 to do so.
Please help. Suggest any method to perform the trimming of pipes.
Thanks in advance.
-Amogh Trivedi
Replies (13)
Message 2 of 14
g-andresen
1. Please show a screenshot with markings for the separation points.
2. Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
Message 3 of 14
Screenshot (230).pngScreenshot (232).pngScreenshot (231).pngHere I am attaching the screenshots of the model and interferences which
are appearing.
Message 4 of 14
g-andresen
try this
günther
Message 5 of 14
Sir I have tried this, this works good when there are two pipes but when there are 3 or 4 pipes then it becomes very difficult to perform. With 3 or more pipes split body is not working unless using extend splitting tool option. With use of extend splitting tool option, it is also removing undesirable portion of bodies.
Can you tell what to do for this?
Message 6 of 14
g-andresen
Try using an (uninjured) offset (dist = 0)surface as a cutting tool, not the tube surface.
günther
Message 7 of 14
Can you please tell me why this error is coming and how it can be avoided. Screenshot (234).pngScreenshot (233).png
Message 8 of 14
g-andresen
please share the file
günther
Message 9 of 14
I am attaching the .f3d file.
Message 10 of 14
g-andresen
1. Result
2. Screencast 1 > your model
3. Screencast 2 > using offset face for split tool
günther
Message 11 of 14
Sir is there any way to Export Fusion 360 sketch to Autodesk Inventor or
Solidworks?
It will be of great help.
Message 12 of 14
g-andresen
take a look here
günther
Message 13 of 14
davebYYPCU
Select Sketch in the browser, right click, and Save as DXF.
Might help....
Message 14 of 14
Ok got it.
Thanks a lot for the help.
