Message 1 of 17
Trick to get units to change from in to mm?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Needed to make some fixtures for some new parts. Received a drawing that was in inches.
I changed the units (Document settings > Units) for the project to inches to simplify using the drawing.
After I completed the model I went to Document settings > Units and changed back to MM (default is checked for this)
During CAM I came across a few things that needed to be changed. When I went to Design and tried to change dimensions, they are shown in MM but when I try to change the value, the entry box is in inches. So it shows MM for the model dimensions but shows inches when trying to change dimensions.
How do I get this project to be pure MM ??
I mean shows MM and also accepts input in MM??
