Tooltips not showing
eerier_bleach0f
eerier_bleach0f
I have tooltips turned on:
According to the "what's new" blog post tooltips should display when hovering over items in the data panel like so:
Not for me though:
Same with projects and folders.
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
yugesh_mahure
@eerier_bleach0f Could you please confirm the build# you are using.(Can be found in Help--> About). Also please check if you are getting the tooltip for same files in List view. Thanks!!
eerier_bleach0f
In list view I only have one file that has a file name long enough to get cut off and finished with an elipses. The tooltip does appear for that file.
Screenshot 2024-08-14 at 10.19.09 AM.pngScreenshot 2024-08-14 at 10.20.46 AM.png
