TOOLPATH WRAP
TOOLPATH WRAP
Farzati.Scott
TOOLPATH WRAP
Farzati.Scott
Ok, so I'm using a toolpath wrap around a cylinder to do a slot.  The path appears to be correct.  However when I go to simulate the initial move shows a collision with the stock?  I tried to have the cylinder with origin in a vertical position as well as setting the Z to the cylinder with no luck.  The tool is clear above the part, so what is happening???
paul.clauss
Hi @Farzati.Scott
Thanks for posting! Sometimes I notice that Fusion shows a collision at the beginning of its ramping or entry move. If you'd like to share the file you are working with I'm happy to have a look and potentially log a ticket. I have seen the simulation show collisions on entry before - these can likely be ignored, just double check your entry heights.
Paul Clauss
Product Support Specialist
