Toolbar appears blacked out
Message 1 of 29
My toolbar suddenly black out when I opened it. I was able to use the software fine until I reopened it and the toolbar blacked out. I have tried uninstalling and reinstalling but the issue is still there.
Here is a screenshot for further detail. I can still click the functions of the toolbar and everything works but the toolbar is blacked out.
Accepted solutions (3)
Replies (28)
Message 21 of 29
info1234567891234567890123
Community Visitor
Community Visitor
i have tried all the solutions listed above, there is error window pops up, saying not found, reinstalling will solve your problem.
Message 22 of 29
beatNXAMS
Observer
Observer
My Lenovo X1 has an Intel UHD Graphics 620 with driver version 27.20.100.9466 - this works.
Under system properties-performance options-visual effects however I have the 2nd option selected (adjust for best appearance)
Hope this helps!
Message 23 of 29
dsouzasujay
Hi @beatNXAMS @Anonymous @info1234567891234567890123 @Anonymous @Anonymous
The latest Fusion 360 Update has the fix, Build number 2.0.10148.(You may need to restart Fusion 360 to see Auto-Update)
Note: After Fusion 360 updated to build  2.0.10148 version, then you can clear the environment variables.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 24 of 29
dsouzasujay
Hi @Anonymous @Anonymous @beatNXAMS @info1234567891234567890123 @Anonymous
Note: After Fusion 360 updated to build  2.0.10148 version, you can clear the environment variables.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 25 of 29
hansen.95
Hi @dsouzasujay
I got it!
The problem for me was that my main Windows 10 user account does not have administrator privileges, so that when I would go to Advanced system settings from (Control Panel > System and Security > System) I had to enter administrator credentials, and when I changed Environment Variables, they were changed for the administrator user account only.
The solution for me was to go through (Control Panel > User Accounts > User Accounts) while logged into my main (non-admin) user account, click on "Change my environment variables". Then I followed instructions to add environment variable QT_OPENGL with value "angle" for my main user account.
Thanks!
Message 26 of 29
AuthenticBenRoberts
Added Environment variable "QT_OPENGL value "angle" " + reboot.
Problem solved, thanks
Message 27 of 29
francis_si26
Community Visitor
Community Visitor
Thank you your solution helped. Adding the OPEN GL with software
Message 28 of 29
laurentHUX4C
Community Visitor
Community Visitor
Cette solution a mis fin à tous mes problemes d'affichages. Ouf !
Message 29 of 29
dsouzasujay
@laurentHUX4C  Merci pour la confirmation. Heureux de savoir que le problème est résolu ! 😊
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
