Toolbar and timeline UI missing - Mac OS
johannesJGAKQ
Message 1 of 8
johannesJGAKQ
The toolbar icons and the timeline icons are completely gone from Fusion.
I have tried the following:
- Restart Fusion (multiple times)
- Sign out and in again
- Clear Cache
- Alt-Command-R to restore default layout
- Uninstall Fusion 360 -> Reinstall
- edit the NGlobalOptions file according to this: https://forums.autodesk.com/t5/fusion-360-support/toolbar-missing/td-p/7432800?us_oa=forums-us&us_si...
All to say, nothing works.
Any ideas???
Replies (7)
Message 2 of 8
mohammed.aliTDPXK
Hello @johannesJGAKQ ,
Can you please try the clean uninstall and see if it works.
 https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-...
Let me know if this helps, Thanks!
If this does not fix, can you please send me the diagnostic log files?
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Message 3 of 8
johannesJGAKQ
Yes, I tried the clean uninstall as well, but no difference. I can see the tooltips when I hover over where I THINK the icons should be, but the Icons themselves are not visible.
Attached is the diagnostics log.
Wasn't able to embed the Screencast recording directly in the post, but the link is here:
https://autode.sk/3eIrHKH
Message 4 of 8
mohammed.aliTDPXK
Thanks @johannesJGAKQ ,
I have shared the log files with the team and get back to you.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Message 5 of 8
mohammed.aliTDPXK
This seems to a isolated issue with your machine, I checked with the team and the team have one suggestion which you can try :
 You can try to switch Qt Quick to software mode. In Terminal,
launchctl setenv QT_QUICK_BACKEND "software"
and re-launch Fusion. See if this is working fine for you
If not you can undo the above changes by following below,
Undo the above:
launchctl unsetenv QT_QUICK_BACKEND
Let me know if this helps, Thanks!!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Message 6 of 8
johannesJGAKQ
Hi @mohammed.aliTDPXK ,
Yes, that certainly fixed it on my machine. Really appreciate you going above and beyond on this.
Kind regards
Johannes
Message 7 of 8
p.waespi
Observer
Observer
after a MAC OS update (Monterey 12.2.1)  I got the same problem.
the solution solved the problem
 - launchctl setenv QT_QUICK_BACKEND "software" -
 many thanks
Message 8 of 8
p.waespi
Observer
Observer
got it again after a reboot of the macbook
what's wrong with Fusion360 and OS monterey?
