tool path generation not completing
I have several 2d models that I cannot get to finish generating the tool paths. I've attached one that stops at 99.1%. any help will be appreciated. I've tried everything I can think of as far as changing the designs and settings.
julia.paganucci
Autodesk Support
Autodesk Support
hi @Anonymous ,
thanks for posting! can you please share your fusion 360 file?
thanks,
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
I've since gotten it to complete yet am now getting the "Warning: One or more passes were discarded due to linking constraints." message. Although I cannot pinpoint what isn't linking, it appears as though everything is there to me, could this be an error?
julia.paganucci
Autodesk Support
Autodesk Support
hi @Anonymous .
this article might give some insight: "Warning: One or more passes were discarded due to linking constraints" in Fusion 360/HSM CAM
This is a warning rather than an error message and can be ignored if the toolpath looks acceptable.
Edit the linking moves (leads and entries) to use less space on the XY-plane. This is usually done by reducing the horizontal lead-in length.
thanks,
Julia Paganucci
