Threading operation no longer outputs feed rate.
dpar15
dpar15
Threading operation no longer outputs feed rate. Same post processor I've used for years no longer outputs feed for threading. It also no longer outputs M8 and M9 for each operation. Just one at beginning and end of program.
Be as humble as your skills require you be.
will_1
Hi @dpar15 ,
I am looking into this more, but in the meantime, does your machine take a G32 threading code? Fine if it doesn't but if it does you could use the most recent post processor on our online library and it would probably work great for you.
Will
dpar15
It does use g32. I'll take look at it.
