- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This might be a cascading set of problems. Here's a link to the design: https://a360.co/2L0GV0s
I'm designing a frame with some cross rods that should be threaded on the ends. It's real simple and looks like this:
0.5" Rod needing threads
This rod is a 0.5" pipe created from a path from a sketch (more on that in a minute). Then I try to use the thread tool to give it threads. I don't really want a fully threaded rod, but for this report I just took the defaults. Note that I selected the rod, and the body of the rod almost disappears during the operation (note the end face only is visible).Thread dialog with defaults
When I hit ok, I get this error.Thread error
I'm not sure what I'm doing wrong. This worked easy peasy in the past.
Another thing that is really odd is that the sketch I used to create the rod has a couple mystery projections I can't delete. Well, I did delete them, but Fusion 360 still thinks they are there. The "manage lost projections" dialog can show them to me, but try as I might, I can't seem to use that dialog to get rid of that. Anyway, that's why there is a warning on that sketch. Would be nice to figure that one out too as I keep thinking I have a problem there :(.
Todd
