This parameter cannot be deleted. It is used in the expression of another param
banksysan
Message 1 of 9
banksysan
I have a dodgy parameter, but I can't delete it.
Parameter deletion failed.
This parameter cannot be deleted.  It is used in the expression of another parameter, ''.
OK
How do I find this mysterious parameter with no name so I can correct it?
Replies (8)
Message 2 of 9
James.Youmatz
Autodesk Support
Autodesk Support
Hi @banksysan,
In the Modify Menu of Fusion 360, you can select Change Parameters.
In here, you can look through your parameters and find the offending expression.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
Message 3 of 9
banksysan
It's not displaying in there.  I suspect it's because it's somehow got there without a name.
Message 4 of 9
daniel_gladyshev
2025 same problem still exist...
literary nothing existing, but cant delete a parameter
Error
Parameter deletion failed.<p>Parameter 'SlotL' cannot be deleted. It is used in the expression of another parameter, ''.
OK
Message 5 of 9
daniel_gladyshev
 you see i cannot delete SlotL and it isn't used in any other parameter.
so now I what, need to start from scratch to get rid of this? and this project is only 5 minutes in. imagine how much stuff like that is big projects lol
@daniel_gladyshev - this post has been edited due to Community Rules & Etiquette violation.
Message 6 of 9
jhackney1972
Attach the problem model.
John Hackney, Retired
Message 7 of 9
daniel_gladyshev
there it is
Message 8 of 9
jhackney1972
The reason you cannot delete the "SlotL" parameter is because it is corrupt in your model.  In the attached video I show the process of repairing it and then deleting it.  I do not know how it became corrupt.  Your model, if the corrected parameter and then deleted is attached.
(view in My Videos)
Message 9 of 9
daniel_gladyshev
thank you sir
