Thicken doesn't line up the edges when I thicken multiple faces
tydye279YSLA
Observer Observer
tydye279YSLA
Observer
Observer
I made a 3D sketch of the outline of the helmet I'm designing, and when I thicken it, the edges don't align. Is there an easy way to make this happen? I've been looking for hours for a fix to no avail.
davebYYPCU
Looks like you are Thickening to outside or symmetrically.
Thicken to inside only should do what you are asking for.
If the surfaces are stitched together before Thickening is another workflow.
Might help….
jhackney1972
Please attach your model.
John Hackney, Retired
tydye279YSLA
Observer
Observer
I updated the post and uploaded it as an .f3d
tydye279YSLA
Observer
Observer
The problem when I thicken to the inside is that the edges still don't line up
davebYYPCU
Thicken is working as expected, if you are not happy with unexpected shoulders and edge directions, then that is due to the surface body construction.
Might help....
obulesub
Hi @tydye279YSLA ,
Did the info from davebYYPCU  help answer your question?
If it did, it’d be great if you could click the "Accept Solution" button so others can easily find it too.
If you’re still needing more help, feel free to share an update here. The community will be happy to jump in with any next steps to help you get where you need to be.
Obulesu | Community Manager
