Message 1 of 9
A joint that won't delete
I have a joint that won't delete. I suspect it is causing problems because once I step past it the component is moved to the jointed position but a copy of the component remains where it was originally. Moving further on in the timeline and Fusion crashes, and if it doesn't, it will crash if the design is saved.
I have moved the timeline to prior to the joint and it won't delete. Move it to beyond the joint and it deletes and the timeline moves before the joint but a greyed out joint remains beyond the timeline marker. Step the timeline over the joint and it is back again.
I saw in a previous thread a possibility of command line solution but it was never provided
