Thermal simulation failing
intositeYS9VP
Message 1 of 13
intositeYS9VP
Am trying to run a thermal simulation. But it keeps failing at the solving portion and doesn't say much why it's failing.
Just this.
_____ 2021-03-03 00:10:31 _____
15831 Tetrahedra :  100.0% of elements (100.0% of volume)
       Face Angle min:  7.76,  max : 157
       Dihedral Angle min:  3.19,  max : 176
       Worst shape ratio :  52  on element 6256
       Worst aspect ratio :  7.4  on element 1015, shortest edge: 0.000123, longest : 0.00702
       Lowest collapse ratio :  0.0278  on element 6256
       Worst Jacobian ratio :  2.25  on element 2763
Base mesh: 29469 nodes, 15831 elements
Solver mesh: 29469 nodes, 15831 elements
Job has finished with errors. Receiving results.
Error: Solver Error
Error: An error occurred while solving the model.
Replies (12)
Message 2 of 13
intositeYS9VP
I just tried a  simple model, and it still fails without much errors. Attached the test file
Test v0: Simulation Model 1 - Study 1 - Thermal
_____ 2021-03-03 00:58:57 _____
2145 Tetrahedra :  100.0% of elements (100.0% of volume)
       Face Angle min:  17.4,  max : 131
       Dihedral Angle min:  17.5,  max : 154
       Worst shape ratio :  5.5  on element 979
       Worst aspect ratio :  3.34  on element 10, shortest edge: 0.001, longest : 0.00607
       Lowest collapse ratio :  0.293  on element 979
       Worst Jacobian ratio :  1.18  on element 1282
Base mesh: 4102 nodes, 2145 elements
Solver mesh: 4102 nodes, 2145 elements
Error: Solver Error
Message 3 of 13
tyler_henderson
I downloaded your file and I was able to solve the simulation successfully.  Maybe there was an issue with our cloud services when you tried solving.  Or maybe you have a pending update to the software.
Have you tried restarting Fusion then solve again?
Tyler Henderson
Principal User Experience Designer
Message 4 of 13
intositeYS9VP
Sorry, forgot to mention i was trying to solve it locally. Yes I've tried restarting Fusion with same errors.
Message 5 of 13
tyler_henderson
Ah, ok.  Local solve requires installing the Nastran solver.  That should happen automatically.  Do you have an internet connection, and have you tried Cloud Solve?  It could be an issue with the local Nastran solver.
Tyler Henderson
Message 6 of 13
intositeYS9VP
Haven't tried cloud solve as I didn't want to waste my credits on just a
test.
Message 7 of 13
tyler_henderson
Have you solved locally before?  If yes, did you see the message about Nastran being installed?
Tyler Henderson
Message 8 of 13
intositeYS9VP
No this is a new computer at work. Have not run any sims on it before.
Just tried a static stress and it failed too. How can I fix it.
Message 9 of 13
intositeYS9VP
I tried restarting the com and still get the error.
2021-03-03 10:15:23,605 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2021-03-03 10:15:23,605 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.process - WARNING :: Exception in Update The Registry is not found
2021-03-03 10:15:23,605 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2021-03-03 10:15:23,606 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2021-03-03 10:15:23,606 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: #        #
2021-03-03 10:15:23,606 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000026F81E68288> #
2021-03-03 10:15:23,606 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2021-03-03 10:15:49,381 - MainProcess(23300) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2021-03-03 10:15:49,382 - MainProcess(23300) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: #        #
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000026F825C3C48> #
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\isaac.wong\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from **deleted**\a95f8c5ccd1169cf841c8219266ac15fc1536633\resources\buildinfo.json
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20201218103501
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2021-03-03 10:15:49,384 - MainProcess(23300) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: **deleted**\a95f8c5ccd1169cf841c8219266ac15fc1536633\resources
2021-03-03 10:15:49,384 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
Message 10 of 13
tyler_henderson
Can you tell me what Fusion build number you have?
Tyler Henderson
Message 11 of 13
intositeYS9VP
Active Plan: Fusion 360, Subscription
Windows 10 (19042)
Message 12 of 13
intositeYS9VP
Ok did an uninstall and clean. Reinstalled and on my first timing solving, i see the Nastran being installed. Now it works. Thanks
Message 13 of 13
tyler_henderson
Ok, great to hear.  I was going to tell you that you were on an older version of the software.  Hopefully it is up to date now and everything will work as expected.
Tyler Henderson
