The most logical way of making this shape
NotTheBeaz
NotTheBeaz
So I am trying to raise a profile to a curved line, I know that I could extrude the profile up and then use the split body tool to remove the section I do not want. However, I'm convinced there is a more logical way using either a solid body loft, or surface loft to create the shape I desire. Anyone know the most logical route?
TheCADWhisperer
File>Export and then Attach your *.f3d file here (with this "solution").
Not sure how Loft would be a solution.
How about Extrude to surface?
Replace Face also comes to mind - but I think I will go with the Extrude to Surface.
Hmmm, Extrude - Intersect would be the fewest number of steps...
Shell would reduce the complexity of the sketch...
So many options...
Fillet features rather than sketch...
Simple SketchesSimple Sketches
It the Attached example the Fillets could have been in the Sketch as you did, thereby not needing Fillet Feature and possibly not needing Shell (if your Design Intent is for open bottom).  Sketch2 could have been simplified by using Feature Fillet rather than sketch fillet.
TrippyLighting
The most logical way would not include a loft. It would also not include filleted sketches or an offset profile.
