The left sidebar with all projects still freezing and is unresponsive.
tdh48
Message 1 of 41
tdh48
The left sidebar isn't responsive. I can't go tom my projects and other stuf. The designbar works fine. Everthing add doesn't respond correctly.
Processor 13th Gen Intel(R) Core(TM) i7-13620H 2.40 GHz
Geïnstalleerd RAM-geheugen 16,0 GB (13,7 GB)
64-bits besturingssysteem, x64-processor
NVIDEA Geforce RTX 4060 Laptop GPU
Editie Windows 11 Home
Versie 24H2
Installatiedatum ‎2-‎2-‎2025
Build van besturingssysteem 26100.3194
Windows Feature Experience Pack 1000.26100.48.0
Replies (40)
Message 21 of 41
berdan_uzan
Here are my diagnostic logs you've requested. I attached them below. Thanks.
Message 22 of 41
anurag_naik
Hi @berdan_uzan, could you also please share us a dump of dxdiag which should capture most of the hardware specs for your machine. Additionally, can you also confirm if there's any VDA software being run on your machine
Anurag R. Naik
Message 23 of 41
berdan_uzan
Here is my DXDiag. I don't what a VDA software is. Can you describe it? I did some research but couldn't find what that is.
Message 24 of 41
anurag_naik
In short is there any Virtual Desktop s/w installed or used through your system?
Message 25 of 41
berdan_uzan
I only have onedrive. Which I don't know if it counts as a VDA software. So I think no, I don't have that kind of softwares.
Message 26 of 41
anurag_naik
Thanks @berdan_uzan for the info
Message 27 of 41
berdan_uzan
Is there any problem with my device? I am still waiting for a fix. Thanks.
Message 28 of 41
berdan_uzan
It's been a long time. I am still waiting for a fix. I am still waiting for your response.
Message 29 of 41
tdh48
This isn't my problem.
My problem is that I can't change or press any buttons into the left sidebar. Al suggested things didn't solve the problem. Is there anything I can still try or do? Is it better to look forward for something else to design my 3d prints?
Message 30 of 41
vinayak_dhame
Hi @tdh48 ,
Can you try to manually rest the Data Panel by following the steps in link.
Also kinldy you share your deatils via direct message to check at the backend
Our team is also investigating on the probelm faced by @berdan_uzan
If my answer helped, please 'Accept Solution'
Vinayak Dhame
Autodesk Fusion
Message 31 of 41
berdan_uzan
@vinayak_dhame wrote:
Hi @tdh48 ,
Is there anything I can do for now? The competition has started. I borrowed a PC from a friend. But I still need a fix. Thanks.
Message 32 of 41
vinayak_dhame
Hi @berdan_uzan ,
Our team is working on the issue.
There is another step if you can check and let us know if this helps:
In Preference Setting:
For Compatibility & Troubleshooting: Change the preference from OpenGL to D3D11, restart Fusion, and see if that improves or fixes the issue.
Vinayak Dhame
Autodesk Fusion
Message 33 of 41
berdan_uzan
I don't have that tab in my preferences menu. Where can I find it? Thanks.
Message 34 of 41
vinayak_dhame
Hi @berdan_uzan ,
Sorry to hear that you are facing this issue.
Our team in working on this and we will soon have an update on this.
I will keep you posted when the fix is available.
Vinayak Dhame
Autodesk Fusion
Message 35 of 41
berdan_uzan
I think I have a new problem with Fusion. I can't open the app right now. There is a textbox saying that some .dll files couldn't found.
Message 36 of 41
vinayak_dhame
Hi @berdan_uzan ,
Could you try to follow the steps given in this link
Reset/Repair the Fusion using the Service Utility tool should mostly resolve the issue.
Do let us know if this helps.
Vinayak Dhame
Autodesk Fusion
Message 37 of 41
berdan_uzan
I fixed that issue by redownloading the Fusion. So, I can open the app right now. But it is still broken.
Message 38 of 41
flipsk
Observer
Observer
I'm also having this issue. Project bar unresponsive, history bar missing, if I can get a project to open the body is invisible. Orgin is also missing. I made a post about it and got no response. Not really happy but, happy I'm not the only one. PLease help us fix this.
Message 39 of 41
tdh48
Thanks for the help and the suggestions. Today it seems to work with
Fusion 2601.0.90 x86_64
Right now I'm installing the latest update and hopefully it will keep working.
Fusion 2601.1.37 x86_64
Now I still have the same issue again.
Message 40 of 41
flipsk
Observer
Observer
My laptop has two graphics cards. By disabling the stock hp graphics driver in device manager and running it off just the geforce, it runs like it used to.
Hope this helps someone.
Next I'll try deleting and reloading the stock driver.
Cheers
