The left sidebar with all projects still freezing and is unresponsive.
tdh48
Message 1 of 41
tdh48
The left sidebar isn't responsive. I can't go tom my projects and other stuf. The designbar works fine. Everthing add doesn't respond correctly.
Processor 13th Gen Intel(R) Core(TM) i7-13620H 2.40 GHz
Geïnstalleerd RAM-geheugen 16,0 GB (13,7 GB)
64-bits besturingssysteem, x64-processor
NVIDEA Geforce RTX 4060 Laptop GPU
Editie Windows 11 Home
Versie 24H2
Installatiedatum ‎2-‎2-‎2025
Build van besturingssysteem 26100.3194
Windows Feature Experience Pack 1000.26100.48.0
Replies (40)
Message 2 of 41
tdh48
Message 3 of 41
aparna_naik
Hello @tdh48, thank you for reporting the issue. Can you please confirm if opening a file via File-> Open Dialogue works?
Can you check if updating to latest version (if not already on it) would resolve this issue?
You can go into Help- check for update. If that does not show an update, go to Help - support and diagnostics - Fusion service utility and do a repair.
Please confirm if your issue is resolved.
Aparna
Autodesk Fusion
Message 4 of 41
berdan_uzan
It is a similar problem for me. Even the Fusion Service Utility does not help. I've allready deleted and re-downloaded the app.
Message 5 of 41
tdh48
Hello Aparna,
Thanks for your response. Opening a file by using the option File and the dialogue works. So I can opening my files and I also see my files into the online environment. I already did a reinstallation of fusion 360 two times. First I removed it normally by the uninstall. Seconds time I removed it by use revouninstaller and removing al the files who where left behind. None of this methods worked.
Today there was an update so I installed that update also. But the project bar doesn't show up correctly and isn't clickable. For now it's totally gray. When starting the application. You can see the normal view but than it's loading a gray picture. I have 8 items into my respository so I'm not above the limit of 10 editable items.
clear cache doesn't work
repair doesn't work
Using another account doesn't work
Right now I'm on the version below.
Fusion 2.0.21550 x86_64
Active Plan: Personal
Windows 11 Home 24H2 (26100.3194
Now it's showing this again.
Hopefully you can help me out with another possible solution I can try.
Message 6 of 41
tdh48
My response seems to disappeared so I try it again.
I did a re installation of fusion by using Revouninstaller for removing all related files to fusion 360.
cleared cache (didn't worked)
repaired the installtion (didn't worked)
tried another account (didn't worked)
updated fusion to the latest version today.
GPU Information
GPU Device: NVIDIA GeForce RTX 4060 Laptop GPU
GPU RAM: 8064 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 572.70
GPU Driver Date: 03/04/2025
Graphics Effects Settings
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
it's still not clickable
Message 7 of 41
berdan_uzan
Do you get the uploading preferences textbox everytime when you close the app? I think it has something to do with this issue.
Message 8 of 41
tdh48
Dear Berdan,
Thanks for your response. I stil get the below screen when closing the app.
Message 9 of 41
vinayak_dhame
Hi @tdh48 ,
For "Cannot close until jobs in progress complete
Can you please try the below:
1. Close Fusion
2. Go to %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\UNIQUE ID\P.login\DELETE jobs.json
3. Go to %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\UNIQUE ID\W.login\DELETE folder Q
4. Go to %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\UNIQUE ID\W.login\DELETE UploadQueuedFileList.xml
5. Now start Fusion
If you still face probelm with the DataPanel can you try below steps as well:
  • Update graphics drivers (uninstall and reinstall too)
  • Turning Fusion manually into offline/online
  • Manual reset of DP
  • Preferences - Graphics > Display > High-resolution canvas graphics on High DPI displays - Uncheck
  • Create a new design and save - In some instances this has triggered the data panel to update and then work normally
Let us know if this helps.
Vinayak Dhame
Autodesk Fusion
Message 10 of 41
tdh48
Dear Vinayak Dhame,
Thanks for sending all the information.
I followed all steps you suggested but none of this steps solved my problem.
Is there any way to get it work?
When I'm closing fusion I still see a flash of the files I have created.
Tijmen
Message 11 of 41
vinayak_dhame
Hi @tdh48 ,
Can you follow the below steps to see if it helps:
  • Launch Fusion
  • Go Offline (manual switch)
  • Close Fusion
  • Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file (OR) \AppData\Roaming\Autodesk\Neutron Platform\Options\<user ID> login__ActiveDocuments file
  • Launch Fusion
  • Editable Document list should be empty
  • Mark a single document editable
  • Go Online
Vinayak Dhame
Autodesk Fusion
Message 12 of 41
tdh48
Hi Dhame,
Thanks for your response again. I can't change the file from Read-Only to editable.
See the picture of the Data Pane I get. When I press the Read-Only button nothing happend.
Message 13 of 41
vinayak_dhame
Hi @tdh48 ,
Thank you for trying the steps provided.
To make the files editable you can try using the link.
Additionally , this link will provide more information related to the 10 document limit for Personal use.
You can also share your user id in private message to me to get more deatils for your account.
Thank you.
Vinayak Dhame
Autodesk Fusion
Message 14 of 41
berdan_uzan
I am having a similar issue. Can you guys help me too? No one is responding to my topic.
Message 15 of 41
vinayak_dhame
Hi @berdan_uzan ,
Were you able to follow the steps suggeted in previous messages?
It will be helpful if you could record a video and share for the issue that you are facing.
Vinayak Dhame
Autodesk Fusion
Message 16 of 41
berdan_uzan
I can not find the files. They are all missing. I am going to record a video as soon as possible. Thanks
Message 17 of 41
berdan_uzan
As you can see in the video, I can not see the data panel. And the timeline UI is getting broken when I hide the data panel. I really need some help for these problems. Me and my team are going to participate in a competition in about 2 weeks and I am the CAD designer of the team.
I attached the video below.
Message 18 of 41
kapil_kugaji
Hi @berdan_uzan ,
Can we have a meeting to see and debug what is the issue ?
Let me know your Location and good time to connect.
Message 19 of 41
berdan_uzan
I am living in Istanbul and we are using the GMT+3 time system. I am actually free today. If it suits you, We can have a meeting anytime until 22.00 (10 pm.) GMT+3. You can mail me.
deniz.uzan29@gmail.com
Message 20 of 41
kapil_kugaji
Please check your mail, I have setup a meeting at 3:30 PM Istanbul time. Please accept.
