Tesselating multiple bodies
Hello, when Brep to mesh was an option I had the opportunity to convert multiple bodies to meshes in one step, now that tesselate has replaced it in the menu it seems the only option is to tesselate one body to a mesh at a time. Is there any way to tesselate multiple bodies at once anymore?
jhackney1972
The process is pretty straight forward and is outlined in the attached Screencast.
John Hackney, Retired
Thanks so much for taking the time to record that process Jhackney1972, I think this should solve the problem for me!
jeff_strater
If you are talking about the Tesselate command in the mesh tab, then yes, that is one body at a time.  I think that was just an oversight though, and will be fixed in a later release.  Till then, use @jhackney1972 's method...
Jeff Strater
Engineering Director
wassi3
As Jeff said, kind of an oversight. On track for next release.
