T-spline model wont thicken
jona.nolakers
Message 1 of 10
jona.nolakers
Halo!
I have made it work by thickening in t-spline editing, which caused a lot of self intersecting surfaces. It worked after fixing those, but now the company that will be prining the model says they need it 0.1 mm thicker. This is where it would be beneficial if I was able to thicken it in brep modelling, which works, up to 0.0001 mm thickness, not the 0.7 mm I need.
Any information on what causes this, or what I can do to make this work apprecuated.
With kide regards
Jona Nolåkers
Replies (9)
Message 2 of 10
TheCADWhisperer
@jona.nolakers
Message 3 of 10
g-andresen
Without an analysis of the construction we can not give any hints.
Please share the file.
File > export > save as f3d on local drive  > attach it to the post.
günther
Message 4 of 10
TrippyLighting
If thickening in the T-Spline workspace cause self intersections, chances are that the same happens in the BRep environment.
Message 5 of 10
jona.nolakers
so sorry, I must have forgotten to attach the file
Message 6 of 10
TrippyLighting
Very nice model!
This isn't ever going to thicken in BRep mode.
The best way forward is to thicken in T-Spline mode, simplify and remove self intersections, so you are left with smooth surfaces without small radii and creases on the inside. That will make it easier to add some thinckness later.
Message 7 of 10
jona.nolakers
what is the reason for this? Just curious for future projects.
Message 8 of 10
TrippyLighting
Offsetting surfaces creates self intersecting surfaces when radii are smaller than the distance you want to offset or thicken.
Message 9 of 10
jona.nolakers
is there a way to avoid radii smaller than, in this case, 0.7 mm?
Message 10 of 10
TrippyLighting
Model differently ?
