System Requirements
System Requirements
jasonlear
System Requirements
jasonlear
I am about to enroll in a class that will use Fusion 360. Will Fusion run on my system?
O.S. - Windows 11 for x64 system
Processor - Intel(R) Core(TM) i3-8130U CPU @ 2.20GHz 2.21 GHz
Installed RAM - 8.00 GB
System type - 64-bit operating system, x64-based processor
Graphics - Intel(R) UHD Graphics 620
jhackney1972
Your graphics chip will be a source of complaint from Fusion 360.  Make sure you adjust your graphics settings to the most minimum settings and turn off special effects.  Your processor also is on the low side but if you are doing simple training, I do not see it being an issue but this is not a production computer.
John Hackney, Retired
jasonlear
Thank you. I believe we will be using it to share and view files.  I am not sure if we will be creating any files or not. Thanks again.
