Sweep Calculation ridiculously slow
bschmu
Message 1 of 11
bschmu
I have a sweep which I didn't think was too complicated (path is 26 arcs) but takes over an hour to calculate out.  Is this issue software or hardware related?  In task manager it looks like fusion is only using 16% cpu and 1gb ram so I'm guessing its software related.
MS Studio
i7-6820HQ 2.7ghz
16gb ram
Geforce gtx 965M
Replies (10)
Message 2 of 11
jeff_strater
share the design here, please.  Hard to say just from the description.  Regarding the CPU utilization, many geometry algorithms are inherently single-threaded. So, if you have a 4 core machine, the maximum CPU usage would be 25%.
Jeff Strater
Engineering Director
Message 3 of 11
bschmu
unfortunately I am unable to share my design.  I'll try to duplicate it in a way that I can share
Message 4 of 11
bschmu
Here's the link https://a360.co/3iEBpgs
Message 5 of 11
bschmu
@jeff_strater Were you able to take a look?
Message 6 of 11
jeff_strater
thank you for the reminder, @bschmu - this had fallen through the cracks in my to-do list.  I did take a look today.  It does seem like this is pretty slow for a sweep that is not all that complex.
I wonder about these curve segments:
which come from these faces:
but, that is just a theory at this point.  I will need to check with the modeling kernel team to see if there is something else going on here.
Jeff Strater
Message 7 of 11
jeff_strater
we sent this off to the modeling so, what is this  team to investigate.  It seems to be a real problem, and we cannot find any problem with your design workflow here, at least so far.  Will update when we know something new.
Jeff Strater
Message 8 of 11
bschmu
Thanks for looking into this!  Nice to know I don't need a new computer 🙂
Message 9 of 11
gulzar.dhanani
Hello @bschmu,
Are you still facing this issue with Compute All? If yes, then  please try the workaround mentioned below :
  • Edit the existing sweep feature through UI Timeline and click OK
  • Now do a compute all,  you can see the compute All is a lot faster
    Please refer to the steps mentioned below in the recording which shows how to the edit sweep feature through UI timeline.
Please let us know if  you have any more queries?
Message 10 of 11
TrippyLighting
@bschmu did you build this natively in Fusion 360 including all sketches?
Message 11 of 11
bschmu
Blast from the past!  If I remember correctly the design started in F360 with an imported 2d sketch dxf and built from there, completely in F360.  As mentioned in msg 6 above, that specific sketch was derived from faces.
Either way that project completed and I haven't taken a look at it in over a year so I can't say if the problem still exists and I don't remember what my solution was.
