svg world orientation
SEIZMICdesign
Message 1 of 14
SEIZMICdesign
Am I mistaken here or did inserted .svg's always take world orientation instead of plane orientation?
Past few times I've brought in an .svg, rather than being able to rotate, scale & flip along the plane coordinates, Fusion360 is offering only the global XYZ axes to manipulate imported vectors.
Is there a setting somewhere that will change this or is it a bug? I can't tell.
Replies (13)
Message 2 of 14
g-andresen
After an SVG import, the curves are fixed (green).
After right-clicking > UNFIX the fixation is removed and move and rotating is possible.
günther
Message 3 of 14
jeff_strater
I see what you are saying. I would say that is a bug. Here I have component1 active, and have picked a face of the component for the sketch plane, but the triad is oriented to the global origin.
[edit] I created bug FUS-97316 for this issue.  Thanks for posting it!
Jeff Strater
Engineering Director
Message 4 of 14
SEIZMICdesign
kay.. I guess you get it, but it's tough to tell from your part. Did you try to put it on a plane that's not in the same orientation as the global XYZ?
But yeah it seems like not normal behavior. 3D sketching not enabled.
And @g-andresen  - I'm mainly referring to initial import adjustment. But to your point, another part of the bug is that when the imported sketch is set to "Unfixed", it is completely untethered to it's surface and can be dragged around anywhere like a component.
Maybe I've got some sort of COVID-related brain malfunction from last week, but I just don't remember this being the behavior of imported .svg files.
Message 5 of 14
jeff_strater
here is another image, which I think should help:
I don't believe that this is a change, but I won't say I am 100% confident that is the case.
Jeff Strater
Message 6 of 14
Phil.E
I'm checking on this and discovered that SVG insert-move triad will only follow the sketch plane coordinate system if the top level of the design is active.
The SVG is inserted onto the chosen plane in all cases so far.
The bug is only reproducible while the child component is active.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 14
SEIZMICdesign
So you selected the plane on the component but it inserted the svg sketch at the global origin? For me the svg is initially on the correct plane, but then the modifier "triad" is oriented to global XYZ, and then not constrained to to original plane; just floats around.
I just had another thing happen where I remembered something being totally different than it really is. I think I may be actually losing my mind..
Message 8 of 14
jeff_strater
No.  The SVG is on the correct plane, only the triad is oriented not with that plane or the active component's coordinate system, but with the global CS.  And, verified that this behavior was present prior to this update.
Jeff Strater
Message 9 of 14
SEIZMICdesign
oh-hooo. Well there it is then. So that's pretty irritating!
That... is a bug right?
Message 10 of 14
Phil.E
Yes, it's a bug.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 14
SEIZMICdesign
What's best way to report?
Message 12 of 14
Phil.E
Your doing it now. Jeff is a top developer and I'm a senior QA. Jeff mentioned the bug report number above.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 13 of 14
jeff_strater
it's already been reported and the bug created.  See message #3
Jeff Strater
Message 14 of 14
SEIZMICdesign
OH hahah sorry guys! Thanks!
