SVG Import
SVG Import
jlsmallwood
Message 1 of 11
SVG Import
jlsmallwood
Having trouble importing svg file from CorelDraw. I've tried multiple different settings on export from Corel and Fusion360 is up-to-date. I'm working on an education license if that matters any. svg file is attached for reference.
I can import, size and get it located where I want but once I hit OK. Fusion360 locks up with the green "working/thinking" bar in the bottom right in a perpetual loop.
Replies (10)
Message 2 of 11
g-andresen
rightclick > Fix/Unfix   > blue lines
günther
I have looked at the SVG again in 2 vector graphics applications and can see that it is unusable because of countless stairs.
Message 3 of 11
jhackney1972
You just have to be patient with large files.  I have attached a model with a sketch created from the SVG file.  As @g-andresen  mentions, if you want to unlock the sketch (green) go into the sketch and window it and then select the Fix/Unfix constraint icon.  Be prepared to be patient again as the sketch is very dense with a lot of data.
John Hackney, Retired
Message 4 of 11
jlsmallwood
Thanks for your reply. I still have a lot to learn about the vector graphics process. Can you explain what "countless stairs" are?
Message 5 of 11
jlsmallwood
Thanks for the help. I tried a few things, including trying other programs to create the svg. I found that Inkscape generated a file that worked better on import.
Still have a lot to learn about these vector files and how best to create them.
Message 6 of 11
martinoT8XCR
Fix constraints?
In which menu context?
Message 7 of 11
g-andresen
@martinoT8XCR wrote:
Fix constraints?
Register: constraints  > (red) lock symbol  or  rightclick > Fix/Unfix in workspace
günther
Message 8 of 11
martinoT8XCR
No it says there was no content from the imported file.
Message 9 of 11
jhackney1972
See the attached Animated GIF.  I am in a sketch, just Inserted SVG, as I execute the command from the Right Mouse click menu..
Message 10 of 11
martinoT8XCR
I did the import svg from other program upon which it compiled a error "empty file"
Message 11 of 11
jhackney1972
Attach your SVG file to your Forum post.  Let others take a look at it.
