SVG file to wrap on a cylinder
darron.lanier
Message 1 of 10
darron.lanier
I am trying to wrap or extrude this logo on the outside of this cylinder. It is an svg file but when i import it into Fusion i can not get it to project to the surface, I have tried it internal and external
Replies (9)
Message 2 of 10
HughesTooling
It would probably be best to share your Fusion design. Export and save as a f3d.
One guess is are you projecting from the source sketch (The one with the svg) into another sketch? You can not project into the same sketch.
Also have you tried the emboss tool rather than projecting sketches?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
darron.lanier
https://a360.co/41C1PGP
here is a link to see the file
Message 4 of 10
darron.lanier
yes i tried to emboss but i canot select my logo . I tried putting a box to select all and tried going to the sketches and select from it ,also tried to unfix it nothing is working. I am wondering if something is wrong with the svg file.
Message 5 of 10
jhackney1972
In your supplied model, you had the graphic vertical on the cylinder, it this what you desire or was it you could not rotate it?
John Hackney, Retired
Message 6 of 10
darron.lanier
I can rotate it scale and move it where i want but after that i can only select it from the tree . And as soon as i try to do something esle with it it will not let me select it again.
Message 7 of 10
HughesTooling
Sorry but your SVG is not a good enough quality for CAD. It has lots of breaks and overlapping curves.
If I delete some of the bad curves I can get it to work. It's up to you to simplify your logo to something with cleaner profiles. Maybe trace over a picture in Fusion. I've attached the design, TIP next time export the design as a f3d.
Mark Hughes
Message 8 of 10
jhackney1972
Attached you will find your SVG file wrapped around your cylinder.  Your SVG file is bad so I repaired it, the repaired one is attached.  You are scaling this SVG down so much that the entities will intersect if you try and Emboss the design on the face.  Mine is Extruded directly to unfolded sheet metal which avoids this problem.  It is a lot of work due to the poor quality of your supplied file but here it is.
Message 9 of 10
jhackney1972
I worked pretty hard on a possible solution for you and you have not said if it will work for you or help you.  Nice to have a little feedback!  If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask.
Message 10 of 10
darron.lanier
My apologies sir
I was in class teaching and just got out
yes it was a help but I have to figure out how to put the part that had to be deleted in so I can engrave the file.      So I like the saying garbage in garbage out.      Thanks for the help
