- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm getting an error on the machine when trying to run a surface inspection. Any suggestions are helpful.
I've downloaded the surface inspection post processor the HAAS.
Created the probing cycle in Fusion and posted.
Loaded the file in the NGC after setting up setting 262 and 261 in the controller. I get an error when the controller
I've followed the instructions on the FUSION video: fusion 360 inspect surface
Errors at N80:
The controller says ERROR 536 "command found on DEPRINT line"
I tried putting DEPRINT[START] first just to see what would happen and got the same error.
Attached is the full code up until the error:
My post processor settings are the same except:
Rotary A axes is on
DWO no
TCPC programming no
Use G0 yes
Use G187 yes
Block number only on tool change yes
Inspection Commissioning Mode no
Other information:
2020 FV4SS with rotary
OMP40
