Supported files
Supported files
Supported files
I am able to import .dwg files to start working, but when I am trying to export my finished project the only file format options I am getting are
.f3d
.igs, .iges
.sat
.smt
.stp, .step
As per the webpage for Fusion 360, all the below formats are supported. Please advice why I am not able to export in other formats (screenshots attached). I am using Fusion 360 downloaded from Apple App Store and currently I am using the Education License.
Solution:By file extension:
  • *.3dm
  • *.asm
  • *.cam360
  • *.CATPart
  • *.CATProduct
  • *.dwg
  • *.dxf
  • *.f3d
  • *.fbx
  • *.g
  • *.iam
  • *.ige
  • *.iges
  • *.igs
  • *.ipt
  • *.neu
  • *.obj
  • *.prt
  • *.sab
  • *.sat
  • *.skp
  • *.sldasm
  • *.sldprt
  • *.smb
  • *.smt
  • *.ste
  • *.step
  • *.stl
  • *.stp
  • *.wire
  • *.x_b
  • *.x_t
By program name:
  • Autodesk Alias (*.wire)
  • AutoCAD DWG Files (*.dwg)
  • Autodesk Fusion 360 Archive Files (*.f3d)
  • Autodesk Fusion 360 Toolpath Archive Files (*.cam360)
  • Autodesk Inventor Files (*.ipt, *.iam - up to Inventor 2019)
  • CATIA V5 Files (*.CATProduct, *.CATPart)
  • DXF Files (*.dxf)
  • FBX (*.fbx)
  • IGES (*ige, *iges, *igs)
  • NX (*prt)
  • OBJ (*.obj)
  • Parasolid Binary Files (*.x_b)
  • Parasolid Text Files (*.x_t)
  • Pro/ENGINEER and Creo Parametric Files (*.asm, *.prt)
  • Pro/ENGINEER Granite Files (*.g)
  • Pro/ENGINEER Neutral Files(*.neu)
  • Rhino Files (*.3dm)
  • SAT/SMT Files (*.sab, *.sat, *.smb, *.smt) - (note: Fusion only supports up to ACIS version 7 - later versions of ACIS SAT files will not be uploaded)
  • SolidWorks Files (*.prt, *.asm, *.sldprt, *.sldasm - up to SolidWorks 2018) (note: SolidWorks drawings, *.slddrw, cannot be opened in Fusion 360)
  • STEP Files (*.ste, *.step, *.stp)
  • STL Files (*.stl)​
  • SketchUp Files (*.skp)
jhackney1972
You are correct, Fusion 360 supports the IMPORT of all your listed formats.  This list is not for supported EXPORT formats.
John Hackney, Retired
