- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Please provide a way to alter the units of a user parameter.
The field is not editable like the other parameter fields. The only option is to delete it and recreate correctly. Also since you can't reorder, the recreated parameter ends up at the end of the list (after the ones your created before you figured out that one was defined with incorrect units).
