Sub assembly components not generating in template drawing
Jacksonldudley
Jacksonldudley
I've recently setup a Drawing template with assemblies components, sheet metal components and flat patterns, however when I generate a drawing with sub assemblies drawings for the components within the sub assemblies are not generated on their own sheets, when i generate a drawing with just a sub assembly the components are generated on their own sheets, is this just how fusion drawings work or is there something i can do to make all the components i a model generate in a single drawing? If not is there a way i can combine to separate drawings together?
MariusBaard
Hi @Jacksonldudley
I have exactly the same problem.
Fusion does not do sub-assemblies, you need to do a separate drawing pack for each sub-assembly, then export to pdf and join all the pdf's together to make one file.
I am busy doing that at the moment with 7 sub-assemblies inside my design, a very painstakingly slow process.
But what can we do until the Fusion team sorts this out?
This is been a problem for over a year now, and still no joy
