Strange color artifacts in pcb rendering
buchwaldjan105
Message 1 of 12
buchwaldjan105
I used Fusion 360 to render a PCB that was created with Eagle. I did this with several projects and it worked well but now I got some problems. First, the PCB has some strange colour faults (the pcb is not solid green, some parts are grey/black). Second, the rendering is very low quality even after some hours of rendering which worked well last time.
Thank you very much!
Replies (11)
Message 2 of 12
trixdropd
Same issue here. How can it be fixed? It looks like random polygons rendering on my eagle-generated pcb board.
Message 3 of 12
5icksteen
I have the same issue. Has anyone solved it yet?
Message 4 of 12
rulleeeee
I'm having this same issue with all my PCBs, is there any solution to this? Kind of makes the rendering useless.
Message 5 of 12
patkami1
I have the same issue with my PCB. How can I solve it?
Message 6 of 12
f.gaetani.srt
Observer
Observer
Hi, I have the same issue, how did you solve it?
Message 7 of 12
trey
Yo @jorge.garcia You have any ideas why this happens and how to fix it.  In nice language...this is very frustrating 😉
If you found this post helpful, please click the "Accept Solution" button.
Trey German
Founder and Chief Engineer
Polymorphic Labs
Twitter | LinkedIn
Message 8 of 12
TrippyLighting
@ryan.bales this has come up in at least one more recent thread and I believe you were involved. It looks to me that there is a Z-fighting problem, but in the project that was shared in that other there was no duplicate geometry. I believe this is a bug!
Usually images applied to geometry are applied as a decal or even better as a texture. However Eagle based designs  do that as a canvas (IIRC). That seems a really odd choice as a Canvas main use is not for rendering.
Message 9 of 12
mroeR7VZB
Hello all, I have the same issue when rendering a Eagle PCB Board in Fusion 360. Rendering is ok except the board has strange artefacts. See pictures. I tried to avoid this failure with a manual generated silcscreen/stopmask in gimp an attach as picture --> no solution. Changing dielectrical priority to fix for board to 0 and components to ex. 1 --> less artefacts, bot not usable
I'm using Fusion 360 Personal 2.0.7046
Regards Martin
dielectric priority changedielectric priority changedefault settingsdefault settings
Message 10 of 12
2141560
Observer
Observer
Message 11 of 12
Same problem here, it happens with pcbs made in both EAGLE and Fusion.555_2020-Mar-18_07-20-09PM-000_CustomizedView26024029443.png
Message 12 of 12
radicdotkey
It's been a year since the initial report of that bug and still no official answer, shame.
