STL FILE EXPORT NO POSSIBLE ANYMORE WHY?
I WANT TO 3D PRINT A DESIGN I MADE WITH FUSION 360 BUT CANNOT EXPORT STLFILES. AN HOUR BEFORE I DID EXPORT IS THERE A RESTRICTION MORE FOR HOBBYIST?
dsouzasujay
Hi @Anonymous ,
Exporting stl may be failing due to below 2 reasons.
  • Fusion 360 service might have "degraded". you can check the status in https://health.autodesk.com page.
  • For a larger design Fusion, fusion translator is consuming huge memory and fails, defect (FUS-79012).
Until it gets fixed, Use Save as STL from the root browser node.
Do let me know if this workaround works for you.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
They were making a server upgrade..
