.stl Exports fails
.stl Exports fails
.stl Exports fails
I have a .dxf file that I'd like to convert to .stl. To this end, I saw on a Youtube tutorial that you can create a new component and then insert a .dxf file in the plane xy, for example. Then you just export the file as .stl.
However, when I followed these steps, the .stl export failed. Any suggestions?
Thanks in advance,
Maria
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Thanks for your response!
Here it's the file
g-andresen
There is only one sketch in the file.
You must first create a body with the help of your sketch via Extrusion ....
You can then create a mesh body.
Rightclick > Create Mesh Body (Option: 3MF / STL)
günther
Hi.
When I try to create a body via Extrusion, an error appears " Cannot complete extrusion. The extrude does not have all the required inputs. Try reselecting the inputs". I'm just selecting the whole scheme. Any suggestions?
andrewhicksuk
Community Visitor
Community Visitor
I am getting a similar thing, I have a drawing I did last week(not massively complicated) which does work today yet I draw a 10mm circle extrude it 5mm, save and then export to .stl and it takes a few mins then says Failed?? so strange.
Any thoughts on this?  Thanks
g-andresen
@Anonymous
What is to come of it?
@andrewhicksuk
günther
