Stitch Issue
Stitch Issue
Stitch Issue
I recently had t-splines stitched together, but unstitched them to modify slightly, when trying to stitch them together again fusion is not recognizing the edge to stitch to, they are almost identical in shape and very close together but not intersection, the tolerance is set larger than the largest gap. I have attached the file, thanks!
Screen Shot 2020-10-05 at 1.58.52 PM.pngScreen Shot 2020-10-05 at 1.58.36 PM.pngScreen Shot 2020-10-05 at 1.58.32 PM.png
jhackney1972
I am sure there was some gaps larger than you measured but no matter.  I would just extend the one body to the distance you have set for you tolerance and be done with it.  I would also suggest to use bodies instead of faces for your mirror feature. Model attached.
John Hackney, Retired
