STEP file export
STEP file export
STEP file export
I want to convert an STL file into a STEP file using Fusion 360. I imported the STL file without any issue. But when I export the part into STEP, I get a 4ko file that doesn't open. What am I doing wrong?
Jean-François
saito.kh
Autodesk Support
Autodesk Support
Hi Jean-François,
Welcome to the Fusion 360 community!
Thanks for posting.  Can you please let me know how you exported into STEP since it requires all bodies to be solid bodies?
I found the below article and movie to convert a mesh model (STL) into STEP before exporting.  Would you check if you have not and try to follow the steps?
How to convert a mesh to a BRep in Fusion 360
QUICK TIP: Mesh to Solid
Thanks!
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
TrippyLighting
Why would you want to convert a .stl file that contains a heavily triangualted mesh into a STEP file that I believe can contain meshes but usually contains solids and NURBS surfaces ?
Hello Trippy Lighting,
I need to concert .stl files into .step because some suppliers will only
accept such format (CNC suppliers, Chinese manufacturers...)
PaulMunford
Just to clarify, an STL file is a triangulated mesh. A STEP file contains a Brep (boundary representation) calculated by vertices, edges and faces.
A Brep is 'Real' geometry made of lines are and circles. A mesh is a faceted approximation.
You can generate a mesh from a brep no problem, but trying to go the other way is no mean feat.
A simple shape can be converted through remake and fusion, but often some manual re-modelling is required.
Can you get hold of the original file the the STL was generated from?
Paul Munford
Technical Onboarding Architect
Linkedin
