STEP file export issue
troydjEPMYB
troydjEPMYB
Hi Fusion Team,
1. What STEP version is used to generate exported designs ?
2. If exported STEP files are AP214 or AP242 compliant, do designs exported to STEP contain meta data on material and appearance ?
jhackney1972
Using a video, I try and answer your two questions.
(view in My Videos)
John Hackney, Retired
TrippyLighting
What transfers across to the STEP file is only the color information  of the  Fusion  360 appearance material. A real appearance material can be much more complex than just the RGB color triplet.
Despite application of a copper appearance the material in the STEP file is still set to Steel properties. To change this, the physical material needs to be changed in Fusion 360.
