Steel reinforced concrete structures
Message 1 of 9
1) Is there any method or command or tool to make Reinforced structures?
2) I want to make a steel reinforced concrete structure but neither concrete nor cement is available in materials library.
Is there any option to add those materials.
3) How can I make a steel reinforced concrete beam in Fusion 360?
Replies (8)
Message 2 of 9
davebYYPCU
1) Yes, but takes preparation and multiple tools, not a click and go tool.
2) Yes, you can edit Stone with concrete properties.
3) Extrude, Revolve, Loft or Sweep the formwork Profile, and
Re enforcing lattice grid in Steel.
Might help....
Message 3 of 9
mickey.wakefield
Hi -
What is the purpose of the design? If what you want is steel re-enforced concrete, then you can certainly create a block of material, and give it a custom defined material that is called "re-enforced concrete" which looks like concrete as well, and might even have a density that would make the weight of such a block correct. Then, on a technical drawing, you could specify that the material used is "steel re-enforced concrete to DIN whatever" or whatever standard you like. This will work just fine for fabrication and manufacture.
If, on the other hand, you want to do a simulation of this structure, and have the material behave as a steel reenforced piece of concrete might, you'll need to either approximate heavily - which is entirely acceptable and commonly done, or you'll need specialized calculation software which Fusion 360 does not currently support.
Lastly - if you are looking to work out just how the re-enforcement should look, and how much of it you'll need, this is a specialized need more commonly found in architectural software like Revit than in a mechanical engineering software such as Fusion 360. Autodesk does provide such software as part of its Architecture and Construction offerings.
Mickey Wakefield
Fusion 360 Community Manager
Message 4 of 9
TheCADWhisperer
@Anonymous wrote:
2) ... but neither concrete nor cement is available in materials library.
You can add any material that you like.
First go to Modify>Manage Materials.
In bottom left of the Material Browser - click the folder and select Create New Library.
Give the library a name and path.
Add a Category (like Concretes, Plastics, Steels) as desired.
Copy an existing material to the Library\Category and edit the name and Properties as needed.
Once and done. You now have a custom Library of your materials.
This library should work across Autodesk products.  (In fact, I simply copied this concrete material from another Autodesk product rather than searching for the properties myself.)
Message 5 of 9
msmith365D8
Can anyone provide a set of steps to add concrete as a material that can be applied as a Physical Material. I have attempted to follow these instructions but I am not having any luck copying the Autodesk Material Library Definitions to a local Custom Materials file. They show as if they are there but when I go to apply them in the model they are not listed.
Message 6 of 9
TheCADWhisperer
@msmith365D8 wrote:
Can anyone provide a set of steps...
Show screenshots of your steps duplicating the process outlined above.
Q. Do you know the path to where you are creating/saving your custm material library?
Message 7 of 9
You need to create a new kind of material if you don't see it in the list.
Message 8 of 9
mickey.wakefield
Hi msmith!
Check out this<> post in the forum! There are a number of links in the posted solution to youtube videos and similar that will show you how to add your own materials to Fusion 360!
One thing to note though: Concrete is a particularly difficult material when it comes to SIMULATION. Its not impossible to do - but because concrete is brittle, its not at all like Steel, or Aluminum - or most of the other "engineering" materials used in mechanical design.....so be careful about that!
Mickey Wakefield
Message 9 of 9
@mickey.wakefield wrote:
Hi msmith!
I agree with you. Thanks for the advice.
