Static Stress Simulation always fails
2511965m
Message 1 of 8
2511965m
I have been trying to conduct static stress simulation but it always fails.
It used to get stuck at around 50-80% while meshing, but that could get solved by making the model less complicated. However, it now fails at the solving stage. I have tried so many times and I have modified the model slightly sometimes but it never worked.
I have attached a few screenshots of the fusion360 screen and I can provide the fusion file if needed.
Is there any solution to this problem?
thank you
Replies (7)
Message 2 of 8
dsouzasujay
Hi @2511965m ,
Can you attach the design that you have issue solving static stress in Fusion 360? You can export by File>Export *.f3d/*.f3d file to your local drive and then Attach it here to a Reply.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 8
2511965m
thank you for your help.
This is the file that I'm working on.
Sena
Message 4 of 8
dsouzasujay
Hi @2511965m ,
I was able to solve this study on first try, i didn't do any changes.
Can you please give another try to solve on your machine?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 8
2511965m
hi,
Unfortunately, it still failed on my fusion. Is this possibly because I am solving locally?
thank you
Message 6 of 8
dsouzasujay
Hi @2511965m ,
Yes, That is one of the possibility.
If your machine memory runs out of memory then it will fail.
Try running it on cloud.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 7 of 8
2511965m
It worked on the cloud and I could get the result.
Solving on cloud initially had a problem and meshing always got stuck at 60% (probably due to the complexity of the model) before I made the change to the model so I just hadn't solved the simulation on the cloud since then because I assumed it wouldn't work anyway.
Thank you for your help and sorry for taking your time with a quite simple mistake.
Message 8 of 8
dsouzasujay
Good to know it solved on cloud.
Please click "Accept Solution" button for one of the answer.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
