Static Simulation Failed at Prepare Model
misc_engineering
misc_engineering
I cannot get a simulation to run on MacOS. It dose not matter what model or how its setup. I cannot generate a mesh either. I have check to ensure NASTARSolver is installed. If I setup a file on my Mac and run it on my Windows machine it runs without problem making me think the problem is specific to my Mac. Are there other file-paths which are case sensitive causing issues? I have had that happen for a few add-ons where I had to change the folder to the case appropriate version for Fusion to find the path. Attached is the error that I get when I try and run a static simulation.
dsouzasujay
Hi @misc_engineering,
Did you try solving the study using Cloud? does it solve successfully?
Can you click on details and then share the screenshot of it.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
misc_engineering
I have tried a cloud solve. Still will not work. I typically setup the simulation on my Mac and then open the file on my Windows to solve. It works but is not ideal. I will run a simulation and get those details shortly.
misc_engineering
Here is a local solve fail log. The cloud solve is just spinning. Will update if anything occurs.
misc_engineering
I left the cloud solve over night and it is still spinning. Here is the screenshot of it.
dsouzasujay
Hi @misc_engineering ,
Can you please try to follow below two links to see if it fixes the problem
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
