SSD For Fusion 360?
SSD For Fusion 360?
pdspinelli
SSD For Fusion 360?
pdspinelli
I have a seagate nytro 1351 (6GB/s SATA III) SSD which has read and write speeds of 560MB/s and 535MB/s, respectively. I was wondering if SSD speeds have a major impact on the performance of modeling, rendering, or simulating, and if they do, is what I have sufficient for those operations? If not, what am I looking for in terms of an SSD?
ryan.bales
Autodesk Support
Autodesk Support
I would say at this point in time, an SSD what we should all be using. I try not to generalize here but they are affordable and perform better.
  • Will Fusion run better on an SSD? Yes, as nearly everything runs better on an SSD.
  • But will it have a major impact on modeling performance? To be honest i 'doubt' it. But since you already have it, that is what i'd use. Major impact factors are few, mostly the processor, then likely RAM/GPU.
  • Does that SSD meet recommended speeds? Nearly all harddrives manufactured currently are suitable.
What it comes down to is that if I were building a new PC to run Fusion today I wouldn't even consider a standard hard drive as an option. This is mainly because Fusion installs locally in user directories on the C:/ Drive with the operating system and we really need to consider system wide performance over that of an individual application when building a PC.
Performance comes down to removing bottlenecks and an SSD is one of the cheapest potential bottlenecks to remove. And its cheaper still because you have one already.
Ryan Bales
Fusion 360 Product Support
