splitting a component
greenwoods1462
Message 1 of 11
greenwoods1462
Hello
Is there a way to split a component in a manner simmerlar to split body.
Alternatively is there a way to extrude a cut through a component.
Sorry if these are basic questions.....just struggling with this point.  I have a component that I am reusing and just want to reduce its height in some instances (changing scale is not applicable).
Replies (10)
Message 2 of 11
HughesTooling
If you can split it with a plane then you can use Boundary Fill and set the operation to New Component. Make sure you uncheck Remove Tools. Boundary Fill is also quite useful making a copy you can modify, just select a body then select the single cell of the body. This is safer than using copy as you can reselect the body if edits to the timeline loss it as a reference.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 11
greenwoods1462
Thank you - I have read your guidance (thank you) and looked at online tutorials but I am still struggling.
I have attached my model.  What I want to do is to seperate the roof (see offset plane) so that I can print the roof seperate from the body.
Many thanks for any further help you can give...
Message 4 of 11
HughesTooling
Can you temporarily break all links to the external designs then Export as a f3d from with in Fusion, just make sure you close without saving after breaking the links. The f3z you attached has to be uploaded to a project and can be a problem to delete.
Thanks Mark
Mark Hughes
Message 5 of 11
greenwoods1462
sorry to test your patiennce but when I download it is always a F3z format.  What is the quickest was to save a f3d format.....
I tried sharing a public link with myself and then downloaded and it still came back as F3Z.
Message 6 of 11
greenwoods1462
sorry worked out how to get the f3d file.....
Message 7 of 11
greenwoods1462
with attachment
Message 8 of 11
greenwoods1462
this is the file....
Message 9 of 11
g-andresen
perhaps this is feasible
günther
Message 10 of 11
HughesTooling
OK I used your f3Z file and it's a bit different using linked designs. What you need to do first is use boundary fill to create a copy of one component, then combine all the others to this copy then use extrude include to isolate the roof section.
Mark
Mark Hughes
Message 11 of 11
HughesTooling
You might want to move the plane to use this face, at the level you had it you trim a thin section off this area.
Mark Hughes
